Complex roots
complex_roots
Hi
Is there a quick and easy way to get the complex roots of an equation?
Thanks
If you convert a real negative number to a complex number with 0 for the imaginary part, it will give you the complex root with the expression component.
If you use the Sqrt component instead of Expression, it looks like it works on negative numbers also without this conversion.
The IAC plugin contains a Polynomial Solver component that gives real and complex roots.
@DanielPiker @akilli
Thank you both!
