Hello to all! I was faced with a certain situation when the curves need to be shifted and glued with others in order to get the effect of continuity of the tapes. At the moment I can’t find a solution, how can I make such a complex shift?
The end result should be surfaces. Smooth angular transition formed by curves. I tried to do this with several GRAPH MAPPER, but this is not the best option, there are inconsistencies of surfaces
