Command TAB
Hi guys, in previous version there was the command TAB for lock movemant. From some reason this shortcut doesnt work more.
Can you gime me advice how to setup this command ?
Cheers,
Petr.
This works fine here in both Rhino 7 and 8 WIP
@martinsiegrist Martin, thanks for your answer. Maybe I have some different setup in my Rhino. Do you know where or how I could maybe manage it in Rhino?
I think it’s a standard tool / command option.
Rhinoceros Help - Accurate drawing | Rhino 3-D modeling (mcneel.com)
I assume TAB direction lock work inside a command like _Line or when dragging an object?
Hi Petr - the tab direction lock is a tap on Tab, not a hold… Just in case.
