those cases of same option, different key is not consistent.
There is many examples.
Also if options get added between Version, those keys might change.
My Wish:
it should always be the first Character.
If there are multiple Options for the same Character multiple Presses of this character should cycle through those Options. Some UI-Feedback like a small flash-up Text, or highlighting the chosen Option.
An older topic - motivation was more from a developer perspective, trying to set the Keys for plug-ins / commands:
Dear @Wim thanks for having a look at this. I am an everyday command line user too, and use those one key characters nearly for all options.
I am only talking about Options that are not linked to the first Letter - see “Cap” example and many more.
For my brain-muscle coordination it seems strange to type different Letters for the same thing.
@stevebaer
I imagine some visualisation / feedback while pressing the keys …
for example like this:
the cap copy cornerstyle overlay should appear as soon as users start pressing c…
or of course it could be a command line flyout similar like the standard command suggestions …
with the same conent… (i like this second option more - even if I do not have a visualisation)
(dall-e did not help much, but reinvented a nice interface with fantastic display mode)
Hi @Tom_P
Yeah… it’s a tough one, seeing as there are just so many command line options in Rhino. But I wholeheartedly agree, that at least the options that are common, eg. cap, close, offset etc., should always be the same letter. I don’t have enough sense/memory in me to remember if any of the Rhino commands have more than one common command starting with the same letter, but the idea of multiple key presses (eg. pressing c 2 times) would be no problem for me personally - but I imagine the whole macro system would have to be revamped.
And again, the muscle memory of the various command line options would be no closer to a solution, since (and I’m just imagining things here for the sake of the argument) a command with the options cap, close and cornerstyle would require 3 c’s for cornerstyle, but a command with only close and cornerstyle would require only 2 - and so we are back to remembering specific combinations for specific commands. Maybe a system similar to the instant aliases, where it allows for 2 or 3 letter combos, but again… I’m not sure if that’s just overcomplicating things
I might not the possible to completely solve the conundrum of command line options, but at least having things like cap and offset should be uniform across commands. Which option should take precedence in the case of multiple options starting with the same letter, probably depends on the user/usage. Maybe what we need is an XML file where we can store our personal preferences, similar to aliases and keyboard shortcuts - but I realise this would be yet another thing to maintain/migrate between versions and yet another source of bugs.
It’s a tough one…
-Jakob
thanks - yep i see the aspects you re writing about.
are you typing blind with “touch system” (Zehnfingersystem in German) - without looking at the keyboard ? (i do)
for me it would be totally normal to (tel my muscles to ) remember “press c” and watch the commanline until it suggests “cornerstyle”. - its a level more abstract then remember a single letter - but c for cap / o for cornerstyle / and l for close will make me mad.
with the current automatic apporach cap, close, cornerstyle, loose yes/no
cap = c
close = l
cornerstyle = o
loose = s; (because l is taken by close and o by cornerstyle)
i agree - but a if it s managed, it s an aspect for rhino to become adult.
a good macro is written with full underscore = international options: _delete=_yes
not d y
for backward compatibility it would be great if there is some kind of versioning tag $v5:_offset _cornerstyle=_Round .... for a Rhino 5 offset interface.
my preferred approach would be a default solution, that perfectly fits for new users as “vanilla rhino standard”. a mapping table / preference / custom settings might nice for older users. - But i am always afraid by the attitude “we do not have a perfect solution - so let the user decide by preference” - there is already to much noise in this direction - and mybe it s also the fault of this fantastic forum ;-(
