If possible, to the command “Length” add option “point”, so that it has the possibility of selecting a first point on the curve (or line) and knowing the distance from this point to another (up to the two extremes), without having to subdivide the curve.
example, I want to know the length from point (A) on up to another point on the curve (or up to the two ends).
I think it is a useful option to be added to the command.
perhaps to emphasize the length (x) with a persistent point
It would be useful in the phase construction of a design, in my opinion.
You could also call “length sub curve”, with a persistent point option that emphasizes the length choice.
@davide76, the _SubCurve command displays the picked length in the statusbar too. You might use it to create a button macro which extracts a subcure and just measures it`s length eg.:
! _-SubCurve _Copy=_Yes _Pause _Pause _Pause _Length _Delete
c.
It would be a more comfortable option in the command length, in my opinion …
Let’s assume you wanted to know the length between point A and point B. Should I split the curve into three parts, use the command and then combine everything. And if there are several points? a slaughterhouse!
In addition, if from point A wanted to establish a length X, for example, 12,5cm, and to fix the point on the curve?
I believe that the length command needs a good dusting (small options, no big deal …).
The macro above does exactly that. Run it and click on point A then B and it will extract a temp subcurve and report its length. Then it deletes the subcurve measured.
That is done with the command _SubCurve, click the first point on the curve, enter 12.5cm. Then the mouse pointer is constrained on the curve and asks for a second point, because Rhino needs to know which side of the curve to keep.
c.
Thanks clement, thanks for help me.
