What command to move a point along a curve by so many mm?
I need to establish where on a curve to make a cut so as to make the resulting curve length 190mm.
Rather than keep cutting and using analyze length in a trial and error way, could I place a point on the curve at the start end and move it by a command along the curve by 190mm ?
Else what way to cut my curve to 190mm long ?
Steve
Try the command SubCrv.
For a point, you can use Divide–>Length
HTH, --Mitch
Cheers Mitch SubCrv did it.
Steve
