Hi all.
Command: _Polygon (Edge)
I thought that it was duplicated object.
But, "No duplicates found. Nothing added to the selection."
What is the season?
Hi all.
What is the season?
I don’t know, Knead- the exe thing tried to install stuff on my machine, more or less endlessly, I had to kill it in task manager. I am not touching that again… Can you just post the zip file directly?
yah Knead that was a bad link. The uploader for the site is working fine now so just use that.
Oops, I’m sorry.
[Viedo][1]
[1]: http://www.freeuploadsite.com/do.php?id=27731
I cannot repeat this- SelDup does find the middle segment here.
Did you make the polygon from WCS 0,0,0? [Video_2nd][1]
[1]: http://www.freeuploadsite.com/do.php?id=27764
Hi Knead - selDup is very strict- objects must be identical in the database- I believe it makes an exception for curve direction but otherwise the data must be the same. In this case the ends are are, microscopically, not the same:
start = (10.730211722818106, -6.1950906266307193, 0)
end = (0, 12.390181253261428, 0)
start = (7.9936057773011271e-15, 12.390181253261437, 0)
end = (10.730211722818106, -6.1950906266307175, 0)
Did you check my “Video_2nd” file?
