Combine two solids -> close surface
Hi all,
I want to combine these two solids to create a compound object…
Boolean does not seem to work.
Is there a way to close the top surface of the box, so it matches the wave shaped solid?
Thanks!
Hello - DupEdge all the open edges and run PlanarSrf, then Join.
Hm - I guess that is not going to wiork if the circle comes exactly tangent to the linear edges - you’ll need to trim ‘by hand’
Cap the box, and then trim the top face with the circular edge.,
That worked, thank you Pascal!!!
