Just Ask For Info
Hi guys,
I have two solid, here is two boxes, I join them together, it is composite solid. I just want to know, whether there is sdk that let me join the two solids into one single solid. In the attached image, you can see the two solids are joined at the red line. if I use explode, then it become a two solid again. But what I want is when you do the explode, it is single a single solid and you will get six surfaces.
Thank you.
Regards
John
Try the BooleanUnion command and then MergeAllCoplanarFaces
thank you.
