Combine separated mesh?
Is there any command that combine meshes even they are far distance away? I need to export to Unity, but Block command doesn’t work which all meshes are still separated. This function is something similar in Blender ‘Join’ command but I’m not sure there is something similar in Rhino.
The Join command in Rhino will join “disjoint” meshes.
Note that you will have to run the command with no objects preselected (just one time), and make sure JoinDisjointMeshes=Yes. I think it’s off by default.
HTH, Jakob
Yes, thanks for the reminder, I keep forgetting that was added as an option in V7.
