Apply ContextMenu to TreeGridView column header (Eto.Forms)
adding a context menu to the Eto.Forms.TreeGridView column header you need to know what column header received the mouse click/down event.
Using:
private void OnMouseDown(object sender, MouseEventArgs e)
    TreeGridCell cell = this.GetCellAt(e.Location);
TreeGridCell (TreeGridCell ) gives you the Column, ColumnIndex and Item as a property. Well it seems to work for the actuall row area, but not on the column header.
@curtisw filed this bug RH-68507 to fix that up.
Kindest
Christian
Just did the update to the current Rhino pre-release (7.20.22165.13001-rc) and it seems this issue is solved.
GetCellAt
Awesome - so now we will be able to implement a custom contextmenu.
Who ever implemented this (@curtisw???) - thank you very much.
Kindest
Christian
