Column Rotation - rhinoInsideRevit
The column below is placed via Rhinoinside Revit using " Add Structural Column" component. The column was modelled using the centerline of the Architectural column. What component / workflow can we use to rotate a structural column to match the Architectural column ( Magenta ) orientation using RhinoInside Revit…
Hi TVA,
You’ll need to set the Cross-Section Rotation parameter.
Thank you @Japhy
