Object rotation in revit
hi, probably silly question,
I placed some structural columns (HEB profiles) that are part of a stair oriented with a different angle from the one given by the project north.
Because of this the profiles are placed y oriented on plane, but I need to rotate them along the stair direction.
To do this I don’t want to change the cross section rotation parameter value.
Thanks
EDIT: found a component by ggRevit that add columns by an axis with the possibility to rotate the location point, but gg sadly is not free so I’m still looking for a way to that.
Since we are unable to place the Element by Plane then the Rotating the Cross Section Rotation Parameter is the way forward.
Please note I changed the post category to Rhino.Inside - Revit.
Thanks
