Colour anomaly
I’m not sure what’s going on with this surface, but there’s something up with the colour. It was created in a script using the OffsetSurface method. Not sure if that matters.
Notice how I can’t change the colour of the surface until I extrude it.
Here is the file:
Colour anomaly.3dm (192.2 KB)
I should mention that this is Rhino 7 SR6 (latest RC)
Thanks,
Dan
RemovePerFaceColors?
(This one gets me every time…)
Maybe, but not as it currently stands. I thought about this a little more, and there’s one more big piece of the puzzle that needs to be mentioned. This surface was originally a closed polysurface with coloured faces. I copied it, exploded it, and it seems the colour assignment is permanently “baked” in even as a surface.* At this point, the RemovePerFaceColors won’t work as its just a surface now.
*But… if I just use the OffsetSrf command this issue disappears. It’s the OffsetSurface scripting method that seems to be behaving differently regarding the colour assignment.
Thanks,
Dan
It works here… Ahh, wait, there is a bug there - if you post-select, you can’t select the surface. If you preselect, it works…!!!
https://www.screencast.com/t/qalWQWOsq
Yes, I see that now as well. There’s definitely something that needs a little tuning up here.
I’ll take a look, thanks.
Hi @pascal,
I see this issue still exists. Mitch’s solution works, but this probably should get fine-tuned (I’m using the very latest RC and it’s still misbehaving).
Thanks,
Dan
Got it this time, thanks.
RH-66197 RemovePerFaceColors: Accept post selected surfaces
