RemovePerFaceColors doesn't work properly
I try to change the wireframe colour after *.stp importing without success.
I fire ‘RemovePerFaceColors’ and I can`t select any surfaces (Geometry:
Valid surface, trimmed surface).
How can I change wireframe color after stp import in another way?
I`m on Windows, Version 7 SR12 (7.12.21313.6341, 2021-11-09) Commercial .
The wireframe colors are probably set per-object, you can select them and via Properties set them to by layer or another desired color.
That is, unless the objects have been imported as blocks…
You are right. That’s why I couldn’t change color. You`ve solved my main problem/question.
Please tell me why that RemovePerFaceColors command doesn`t allow for selecting surfaces after triggering command? Is it a bug or not?
If you are talking about single surfaces, they are not considered to have “per-face color” currently. That condition only applies to polysurfaces. When a polysurface that has per-face colors is exploded, the face colors are attributed directly to the object as object colors, so the surface no longer has a “per-face” color attribute.
