In Rhino 5 we can edit the colors.txt file and add our own colors, but this doesn’t seem to be working in WIP. Is the color list somewhere else now?
Hi Gavin - thanks, I see that, we’ll fix it.
I see the default path is incorrect - the actual path is
“C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\6.0\Localization\en-US\Support\colors.txt”
and options is looking one level up:
“C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\6.0\Localization\en-US\colors.txt”
For now, you can move the file up one level or set Options > Advanced > Rhino.Options.Support.DefaultColorList to the path where the file is currently installed…
https://mcneel.myjetbrains.com/youtrack/issue/RH-40952
Thanks Pascal, I set the options to the correct path and is working now.
