Cockroach Plugin: Export point cloud with normals?
I am using the Cockroach plugin in Grasshopper to create point clouds from Meshes, which I am visualizing in Unreal Engine. It works great so far, but I can’t work out how I export point clouds with normals. If I create the point cloud in Grasshopper with normals and bake it to Rhino, it seems to loose the normals.
Then in Rhino:
And after exporting as text file:
How can I export the point cloud with normals?
Curious why Cockroach doesn’t have a point cloud exporter themselves, since Rhino seems to not allow anything other than .txt. That is okay and I am using Cloud Compare to turn them into .las files. Or am I the only one who wants to turn a mesh into a point cloud and export it and not the other way round, like probably most people?
Maybe @Petras_Vestartas can help?
It does seems to work on ply files:
And regarding this:
To put it simply, the development takes most often on free time without much resources. The Cockroach somehow was started from a wish to have at least some sort of tool for minimal pointcloud manipulation and feeded by a few research projects that needed to be done.
I see, thanks for the quick reply! To be honest I was not aware that .ply could export point clouds. I also thought that when baking the normals were already gone, since Rhino’s Details panel showed only the point locations and not the normals.
I exported to PLY now and the normals are indeed in the file.
Thanks!
