Coccoon/ refine error
I am trying to use the refine and coccoon. The coccoon works fine until I use refine. It gives me the error balloon. The balloon says:
  1. Solution exception:Could not load file or assembly ‘Plankton, Version=0.3.4.0, Culture=neutral, PublicKeyToken=null’ or one of its dependencies. The system cannot find the file specified.
I would appreciate the help.
error%20capture
This is what I get whenever I try to use refnie.
You certainly need a plankton dll that could be shipped with a kangaroo version. There must be some discussion on plankton on old grasshopper forum.
https://www.grasshopper3d.com/m/group?id=2985220%3AGroup%3A875392
@luisadrianortiz1 You can manually install the Plankton version you need from Github. I did this on a Mac with Rhino v6 and the error went away.
