this relates the Area center of the “inside curve bounding rectangles” to the “outer curve bounding rectangles”
it will fail only if inside curve bounding rectangle Area center will fall outside outer curves bounding rectangles… which means something that is in the “inside curve” parameter happens to not be an inside curve
OpenNesting help_Re.gh (22.6 KB)
