Cmd+0 regularly not working
cmd+0 to browse between opened gh file is regularly (feels like 50% of the time) not working. It shows the opened scripts, but does not open them. Unfortunately, I have to quite figured out, what causes this. Did someone else experience the same issue?
Here is a short video of the behavior:
Yes, for me it’s exactly the same! The canvas turns semi-translucent white and the open document thumbnails appear, but switching between the documents isn’t possible by keyboard or mouse.
This issue is still here. Cmd+0 only works some of the time, making it impossible to use.
Can someone take a look at this?
Cheers, Rudi
@curtisw, @dan this issue still persists
just gets stuck in the mode, where it shows all the GH scripts that are opened, but does not actually open them.
This should be an easy fix with a lot of value.
@dan, @curtisw could you create an YouTrack item for this and look into it?
Created. Thanks for reporting.
thank you sir, hope this is an easy fix!
it still does not work properly…
cheers, Rudi
@rudolf.neumerkel thanks for the additional poke!
I’ve just pushed a fix for 8.14 for this. Thank you for your patience.
Cheers,
Curtis.
Amazing, thanks for the fix!
it finally works, thank you!
@curtisw, it shortly working and after the recent updated stopped working again…
@rudolf.neumerkel what’s your _SystemInfo? It seems to work as expected here when testing this in 8.14.24314.22002
Rhino 8 SR13 2024-11-6 (Rhino 8, 8.13.24311.03002, Git hash:master @ b6593276781d516da56f01162c4db7dda67089d0)
License type: Educational, build 2024-11-06
License details: Cloud Zoo
Apple macOS Version 15.1 (Build 24B83) (Physical RAM: 16GB)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,1
Language: en
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
  Apple M1 Pro
    Color LCD (2056 x 1329 @ 120.00Hz)
GPU Vendor: Apple
USB devices
  Generic: USB2.1 Hub
  Generic: USB2.1 Hub
Bluetooth devices
  None
Third party kernel extensions
  None
Third party plugins
  /usr/lib/swift/libswift_Builtin_float.dylib
  /usr/lib/swift/libswift_errno.dylib
  /usr/lib/swift/libswift_math.dylib
  /usr/lib/swift/libswift_signal.dylib
  /usr/lib/swift/libswift_stdio.dylib
  /usr/lib/swift/libswift_time.dylib
  /usr/lib/swift/libswiftsys_time.dylib
  /usr/lib/swift/libswiftunistd.dylib
  /usr/lib/swift/libswiftDistributed.dylib
  /usr/lib/swift/libswiftObservation.dylib
  /usr/lib/swift/libswiftMLCompute.dylib
  /usr/lib/swift/libswiftFileProvider.dylib
  /Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
  /usr/lib/usd/libusd_ms.dylib
  /usr/lib/swift/libswiftSpatial.dylib
  /usr/lib/swift/libswiftNaturalLanguage.dylib
  /usr/lib/swift/libswiftSynchronization.dylib
  /usr/lib/swift/libswiftGameplayKit.dylib
  /usr/lib/swift/libswiftSpriteKit.dylib
  /usr/lib/swift/libswiftWebKit.dylib
  /usr/lib/swift/libswiftGLKit.dylib
  /usr/lib/swift/libswiftMetalKit.dylib
  /usr/lib/swift/libswiftModelIO.dylib
  /usr/lib/swift/libswiftSceneKit.dylib
  /usr/lib/swift/libswiftVideoToolbox.dylib
  /usr/lib/swift/libswiftMapKit.dylib
  /Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libkaramba.dylib
  /Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libiomp5.dylib
  /Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libmetis.dylib
  /Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libarpack.2.dylib
  /Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libc++.1.dylib
  /Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libopenblas-r1.dylib
  /Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libgfortran.5.dylib
  /Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libgcc_s.1.1.dylib
  /Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libquadmath.0.dylib
  /Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libc++abi.1.dylib
  /Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework	"Renderer Development Kit"	8.13.24311.1002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp	"Commands"	8.13.24311.3002
  /Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp	"Snapshots"	8.13.24311.1002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp	"RhinoCodePlugin"	8.13.24311.3002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp	"RDK_EtoUI"	8.13.24311.3002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp	"MeshCommands"	8.13.24311.3002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp	"BlockEdit"	8.13.24311.3002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp	"Rhino Render"	8.13.24311.3002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp	"RhinoCycles"	8.13.24311.3002
  /Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp	"AnimationTools"	8.13.24311.1002
  /Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp	"SectionTools"	8.13.24311.1002
  /Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp	"Legacy Rhino Render"	8.13.24311.1002
  /Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp	"Displacement"	8.13.24311.1002
  /Applications/Rhino 8.app/Contents/PlugIns/import_STEP.rhp	"STEP Import"	8.13.24311.1002
  /Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp	"PanelingTools"	8.13.24311.1002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp	"IronPython"	8.13.24311.3002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp	"Grasshopper"	8.13.24311.3002
In RhinoWIP it interestingly works
btw i also tested it on antother mac in R8, same problem
btw. I already tried with and without Rosetta, no influence
Hey @rudolf.neumerkel,
This was fixed in 8.14, which will become SRC later today or tomorrow. When it comes out please give it another try.
Cheers,
Curtis.
RH-80223 is fixed in Rhino 8 Service Release 14
works again, thank you!
