Hey guys, so, i got the Rhino 6 and here, the Closest points (CPs) got a new plug, and i think this new one is why i cant get the same result as before.
So, the new button of CPs got P(point) C(cloud) N(count). I connect the P to Populate 2D; C to Evaluate Surface; as i did before for the final result in Voronoi frame. I use this Evaluate Surface, w/ a MD Slider, so is easy to flow along the final Voronoi frame, BUT, in the past versión, as i move the MD Slider; the generated polygons, follows that Evaluate Surface/Closest point with.
Now, if i move the MD Slider, from the Evaluate Surface, yes, it moves together with the closest point, but, the generated polygons, dont follow anymore that movement
Idk if is the new N(count) or another new plug from the Evaluate Surface.
NOW
BEFORE
Thank you all.
