I would like to close the Standard Toolbar container at the top, but did not find a solution yet. With the Rhino 7 options I have it does not close and I can’t find anything in the settings either.
I know I can close the side bar container in c# with
Rhino.UI.ToolbarFileCollection.SidebarIsVisible = false;
The top container is not visible in the settings where I can enable or disable the sidebar.
Other things I tried is closing all toolbars and panels but no succes.
try
foreach (var f in Rhino.RhinoApp.ToolbarFiles)
f.Close(false);
catch { }
foreach (var p in Rhino.UI.Panels.GetOpenPanelIds())
Rhino.UI.Panels.ClosePanel(p);
Is this already possible in Rhino 8? If yes, then where can I find the option in settings or with C#?
Regards,
Jordy
