ClippingDrawings: Background Lineweights from Object
Problem Description
In clipping drawings, lineweight inheritance is only applied to the geometry being cut. All background geometry is displayed using a uniform, single line thickness. This removes the natural visual hierarchy of the model and makes technical drawings harder to interpret.
To improve readability and match the behavior of Make2D, it would be valuable to have an option for background geometry to also display using its assigned object lineweights. This would allow less important geometry to appear lighter and more prominent elements to remain visually dominant, even when they are not intersected by the clipping plane.
Hi Jon -
In the Rhino WIP, there are a lot more options, and the background objects can be set to use the linetype of the 3D parent object.
