How do I delete a clipping box or at least turn it off.
ClippingBox and ClippingBoxEdit are new features in V9 Beta which are still under development.
Hi David -
I’m getting “Unknown command” for both in the Rhino 9 beta I’m running.
@Wim Rajaa made it available through PackageManager.
I’ll be providing some feedback. For the current project I’ll revert to using clipping planes.
You can simply select and delete the box. To turn off in a viewport, select the box, and in the Clipping-Plane Properties, uncheck the viewport. Does that help?
@Rajaa The box is not visible.
Added: Tested again after restarting Rhino and the box is now visible. I’ll let you know if the problem occurs again.
