Take a look at the video attached. When I add a clipping plane to the scene, in the perspective viewport, the name of the viewport will disappear. As soon as I delete the clipping plane everything works as expected.
https://www.dropbox.com/s/uh63r0z1akcb6b9/Rhino%20clipping%20planes%20Mac.mov?dl=0
Rhino clipping file mac.3dm (3.0 MB)
Software information
Software versions
Rhinoceros version: 5.4 WIP (5E334w)
Rhinoceros path: /Applications/RhinoWIP.app
IronPython version: 5.1.2015.131
WIP expiration: 19 January 2018
Language: en-ES (MacOS default)
macOS version: Version 10.12.6 (Build 16G1036)
Plug-ins
None
Third party kernel extensions
None
Hardware information
Computer hardware
Hardware model: MacBookPro11,3
Processor: Intel Core i7-4850HQ CPU @ 2.30GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: NVIDIA GeForce GT 750M 2048 MB
Memory: 2048 MB
Screen size: 1440 x 900
Displays: Color LCD (221dpi 2x)
USB devices
Apple: Card Reader
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 NVIDIA-10.17.5 355.10.05.45f01
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 8x
Mip map filtering: None
Anisotropic filtering: None
Hi @jespizua
Thanks for reporting this and for submitting a video and a file. Unfortunately, I’m not able to reproduce this on my end with your file. The main difference between our systems is the version of macOS. I see you are running:
whereas I am on:
10.13.3.
So I went ahead and test on macOS 10.12.6, but I still could not reproduce this. Frustrating. It looks like you are reliably able to reproduce it with any file.
Anyone else seeing this one?
Hi @dan, thanks for taking a look at this. I confirm this is still happening using 5.4 on both my machines, 10.12.6 and 10.11.6
It happens here when I move the clipping plane using Gumball, if I use regular move tool everything is normal. So, let’s make it clear:
1 Create a box in the perspective viewport
2 Create a Clipping Plane in the same perspective viewport
3 Activate Gumball and select the clipping plane
Each time I select the clipping plane having Gumball activated the name Perspective will disappear from the viewport, as soon as I deactivate the clipping plane everything come back to normal.
Can you reproduce it?
yeh I see this too, it happens in any viewport you have active with a clipping plane and gumball active, the viewport names disappear, when you deactivate the clipping plane they reappear, no biggie but something not quite right
Not sure why your first explanation didn’t work for me. Your second listing of steps allowed me to reproduce this one. Logged as RH-44807. Sometimes it takes “show” and “tell.” Thank you for being explicit.
