Clipping plane issues
See video:
After the first gumball move, I can extrude the clipping plane with the gumball.
Result is an uncapped view, which is quite handy.
If that is intended, why only after the second selection?
The section style doesn’t display at all.
Not in the viewport, not after ‘Create Drawings’.
Tapping F1 in the Section Style dialog leads to nirvana.
I want to have a viewport that isn’t capped.
How?
SysInfo
Rhino 8 SR9 2024-6-11 (Rhino 8, 8.9.24163.15301, Git hash:master @ 17c7f1c7c05ff0e0b5b12288d13a911b1f0767b4)
License type: Commercial, build 2024-06-11
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.9.24163.15301
Hi Charles -
Thanks, I’ve put this bug on the list → RH-82548 Gumball: Extrudes a Clipping Plane
By default, objects take the section style from their layers:
You can change this to By Clipping Plane to use the section style of a clipping plane:
I’ve reported this as RH-82549 Section Style: F1 Help Leads Nowhere
Turn off Use section styles and Show fills in the display mode settings:
Now I got it.
It’s an Object property, not a Clipping Plane property.
Thanks.
Or even shorter in the Display panel:
Thank you, all questions answered :smiley:
