Clipping Plane directly on a face
Hello guys, I would like to know if there is a straight-forward way to make a clipping plane onto a face of an object, meaning the plane would be parallel to this face, as long as its a straight face, and cut it normal to this face. For now my workflow to achieve it is to place the Cplane on the designated face by Cplane>Surface and then creating the ClippingPlane (and then return the Cplane to World).
Since I am coming from Inventor and doing the transition to Rhino right now, Im used to a feature that easily let you choose face (or several faces) and cut through it.
My purpose is basically see what’s going on into my objects in Rhino because Im assemble parts into parts, so sections help navigate, measure, and checking.
*Im using Rhino 9
Thank you very much in advance!
I’m not familiar with the Inventor process but by your description this is straightforward.
Clip
Start the “clipping plane” command and select the 3 point option.
Pick 3 points on your planer surface and your done. You can use any 3 points that represent what you want a section thru it doesn’t have to be a flat surface or even a single component. You can move this clipping plane anywhere you want to see the details. Using Gumball to move the clipping plane is also useful way to move it around.
This can probably be turned into a macro. Then it can be assigned to a button or alias.
@ken_miller suggestion can probably be macro-ed also.
