Hi there, I am dealing with a couple of bugs when drawing out of a clipped area.
I am using Rhino 8 clipping planes to simulate a ClipXref (similar to Autocad), using a worksession. When selecting the clipping plane properties, I am selecting only one layer, since the idea is to be able to draw around the clipped area, nevertheless Control points are not showing/ and Osnap features are not working correctly. Any idea of how to solve this problem/ bug? Thanks in advance
Hi Miguel - I need a little more information - a simple example file that shows the problem would be the most helpful.
Hello Pascal!
Thanks for helping, let me know if this is clear.
So, when I select controlpoints out from this clipped area, they do not appear. (but they do inside the clipped area, even if it is an external file). Also osnap (intersection for example) not working outside the clipped area (it works inside the clipped area)
Let me know if this is enough
Hello Pascal,
Any news on this subject?
We see major advances in Rhino8 2D drawings wise, nevertheless these bugs should be solved asap, as they make the workflow less efective.
Thanks in advance
