There are often instances where an outline created from objects will consist of a number of small segments over the extent of a striaght line. I like to have my curves and closed curves as simple as possible before using them to create surfaces. Is there a macro or command that would clean up curves with this issue?
SimplifyCrv, Convert and Rebuild will get you where you want to go. It may not be possible to do it automagically though… some user decision making will be required depending on geometry.
-A
I like that term!
Thanks
