Clean edges, ugly solids
Why is this happening?
I extruded this from regular circles and line shapes like normal.
It’s happening to multiple (circular) solids in this rhino file. I tried exporting this part seperately to share on the forum, but isolated in it’s own Rhino file, the solid looks normal…
Unfortunatly I am not allowed to share the entire Rhino file.
(Also what is the name for this effect, English isnt my first language, I sure there is a word for it…)
Hi Simon, Can you provide your SystemInfo and small example (if possible), thanks.
Kick up your render mesh settings so the flat polygonal mesh facets better fit your surfaces.
https://wiki.mcneel.com/rhino/meshfaq
Hi Simon - can you post the file anyway, even if the object looks OK by itself?
Hi All,
I’ve attached the isolated model “ugly.3dm”. I also included a bigger part of the model. I deleted most sensitive information , so should be okay to share it like this.
I had already closed the model, I had to re-open it to reply in this topic, weird thing is, the part didnt look nearly as choppy now as it did before, still not great though.
I also included the SystemInfo. Although my coworker was complaining about the same issue.
WERKFILE PUZZEL.3dm (15.1 MB)
ugly.3dm (57.2 KB)
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15001, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Commercial, build 2024-01-09
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.0
Computer platform: DESKTOP
  Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 12-5-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 527.56
        - Secondary monitor attached to adapter port #0
        - Windows Main Display attached to adapter port #1
Secondary graphics devices.
  Intel(R) UHD Graphics 770 (Intel) Memory: 1GB, Driver date: 10-29-2023 (M-D-Y).
        - There are no monitors attached to this device!
OpenGL Settings
  Safe mode: Off
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 12-5-2022
  Driver Version: 31.0.15.2756
  Z-Buffer depth: 24 bits
  Total Video Memory: 8 GB
  C:\Users\simon\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\CommandTracker\8.0.0\CommandTracker.rhp	"CommandTracker"	8.0.0.0
  C:\Program Files\Rhino 8\Plug-ins\Commands.rhp	"Commands"	8.3.24009.15001
  C:\Program Files\Rhino 8\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	8.3.24009.15001
  C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp	"Legacy Rhino Render"
  C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	8.3.24009.15001
  C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp	"MeshCommands"	8.3.24009.15001
  C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	8.3.24009.15001
  C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp	"RhinoCodePlugin"	8.3.24009.15001
  C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	8.3.24009.15001
  C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 8\Plug-ins\MPlane.rhp	"MPlane"
  C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp	"SectionTools"
Unsure if I ever touched these settings or I if I’m using application defaults.
By the way, I am mostly using the viewports in ‘shaded’ mode.
In Simple controls, you should see a major difference between Jagged & Faster, and Smooth & Slower.
Knowing that it’s just “eye candy” now and not a problem with your file, you can tweak the settings according to your own needs.
Cheers
Hi John,
Is Smooth and Slower the default?
I just think it is wierd, because I never had any issues like this before with my current settings, and the problem seems to be appearing and dissapearing. (When reopening the file and when exported as an isolated object the solid looked just fine)
I am a bit hesitant to mess with settings I don’t fully understand and have been working quite well for years for me.
Could it be the model is taxing my computer too much somehow which causes the rhino render engine to simplify some of the shapes? This explanation already sounds far fetched to me, because I’ve worked with far more complex models and never really encountered somehting like this
Hi Simon - our default templates are set to use Smooth and Slower. In the file you posted, I do not see anything that looks terrible so far - certainly not like your original image. But if I explicitly set Smooth and Slower, it looks pretty bad… I’ll invesigate.
It should look OK with these settings:
Hi Pascal,
Changing the maximum edge to surface distance from 0 to 0.1 , did solve the issue.
My other settings seem to differ quite a lot from yours, should I change them as well ?
Hey Simon -
No, if you have found a combination of settings that works for the file that you are using, that’s fine.
