I always face problem with surface when extruding 2d round edge drawing and when i render it, it doesn’t render well.
Please help me.
Hi, this is simply your display mesh settings. In Options/DocumentProperties>Mesh, if you set it to “Smooth and Slower”, does that help? Otherwise you might need to set a custom mesh setting. See this Wiki page for more info.
HTH, --Mitch
You can also clean up by using DivideAlongCreases > SplitAtTangents=Yes. I’d set the Extrude command line option to SplitAtTangents=Yes if it is not.
thank you so much…it is working…
