Hi everybody ! I’m a new french student that start learning how to use Grasshopper !
I tried to model a structure made with these circles. Actually, i drew a circle and divided it, then I created circles from the points of the division. And then, I asked to create points at the intersections of all these circles (So each vertical post is on an intersection).
But now, I would like to get straigth beams like if there was a little straigth beam between each post (I drew it in blue on the pic).
Do you know how I could find any solution to do that ? I’m not sure that it was relevant to start by these intersections because the lists of points are really messy ! You can find the files under the picture !
Thank you very much for your help ! I hope I could help someone one day !
Test_Poteaux_Circulaire.gh (10.8 KB)
Test_Poteaux_Circulaire.3dm (3.1 MB)
