I have input some data which I have managed to plot using a series of points and generate a 3D graph. I am trying to then add a parameter which will plot circles onto those points where the circle radius is determined by the z-axis. I.e the greater the number in the z-axis the greater the radius of the circle. If anyone could help that would be great.
I wanted Y illustrated as well. This is much closer to what I was looking for, however the size of the circles are relative to each string of data. I was hoping for the circles to be larger the greater the z value. I have attached an image which hopefully explains what I mean better.
This is much better with the Y value the same actually. However I would still like the size of the circle to be relative to the overall z value. Rather than attached to the confides of each branch of data. Thanks
