Option Explicit
Call Main()
Sub Main()
Dim txt
txt = “-1-” + chr(10) + “-2-” & chr(10) + “-3-”
Rhino.AddText txt, Array(0, 0, 0)
End Sub
results in:
Option Explicit
Call Main()
Sub Main()
Dim txt
End Sub
results in:
Hello - It may be AddText() that is doing this - if I copy to the clipboard and paste into a text editor I do not get the leading space. @dale - do you have an idea? vbNewLine has the same result.
Call Main()
Sub Main()
Dim text: text = "X" + chr(10)+ "3"
Rhino.Print text
Rhino.ClipboardText text
Rhino.AddText text, array(0, 0, 0)
End Sub
Hi @Asterisk, why concatenate with a + and & sign ? Below seems to work over here, i do not get the blank space, even with your example code:
txt = "-1-" & chr(10) & "-2-" & chr(10) & "-3-"
Or this:
txt = "-1-" & vbCrlf & "-2-" & vbCrlf & "-3-"
Maybe this is a language specific problem ?
_
c.
It was “&” originally and I tested if “+” would work or even fix the issue. So…
wasn’t aware of vbCrlf
RH-52261 is fixed in the latest Service Release Candidate
