hi, i’ve got a script, that since V6, addtext doesn’t work well, see the picture:
it write the two first and last letters of string of caracters…
Hi @onlyforpeace,
Can you post the portion of your code that isn’t working, so we can run it here?
– Dale
that is a code to generate GCODE for foamcuting with CNC Hot WIRE
Call Main()
Sub Main()
Dim strtraj1,strtraj2
Dim arrpt1,arrpt2,strpt1
Dim plane1,plane2
Dim fso,f
'Create file system object (FSO) to be able to work with file system
Set fso = CreateObject("Scripting.FileSystemObject")
'definition du chemin du dossier d'enregistrement
Dim chemo,chem,nomfichier,nprog,pos,seq,newchem,chemprog,chemprogtemp
chemo = Rhino.documentPath
If Not isnull(chemo) Then
'definition du nom de programme
nprog = rhino.GetString("nom de programme")
If isnull(nprog) Then Exit Sub
End If
pos = instr(chemo, "ETUDE")
If pos = 0 Then pos = instr(chemo, "Etude")
seq = Split(chemo, "\")
newchem = left(chemo, pos - 1)
chemprogtemp = newchem & "USINAGE"
If Not fso.FolderExists(chemprogtemp) Then
fso.CreateFolder chemprogtemp
End If
chemprog = chemprogtemp & "\" & "PROGPSE"
If Not fso.FolderExists(chemprog) Then
End If
nomfichier = chemprog & "\" & nprog & ".iso"
plane1 = rhino.GetObject("selectionne le plan")
plane2 = rhino.GetObject("selectionne le plan")
Dim box1,box2
box1 = rhino.BoundingBox(plane1)
box2 = rhino.BoundingBox(plane2)
Dim strplane1,strplane2
strplane1 = Rhino.PlaneFromPoints(box1(0), box1(1), box1(3))
strplane2 = Rhino.PlaneFromPoints(box2(0), box2(1), box2(3))
strtraj1 = rhino.Getobject("selectionne le parcours 01", 4)
strtraj2 = rhino.GetObject("selectionne le parcours 02", 4)
arrpt1 = rhino.curvepoints(strtraj1)
arrpt2 = rhino.curvepoints(strtraj2)
If ubound(arrpt1) <> ubound(arrpt2) Then
rhino.print "pas les même nombre de noeud"
Exit Sub
End If
Dim inter1,inter2,i,line,ox1,oy1,ox2,oy2
i = 0
'création du fichier texte
Const ForReading = 1, ForWriting = 2, ForAppending = 8
'entête de programme----------------------------------------
Set f = fso.OpenTextFile(nomfichier, ForAppending, True)
f.write("//NOME= DUEASSI")
f.write(chr(13) & chr(10) & "//DIMX=500")
f.write(chr(13) & chr(10) & "//DIMY=500")
f.write(chr(13) & chr(10) & "F13" & chr(13) & chr(10) & "HM10" & chr(13) & chr(10) & "G92" & chr(13) & chr(10) & "G60" & chr(13) & chr(10) & "G63" & chr(13) & chr(10) & "G99")
For i=0 To ubound(arrpt1)
line = array(arrpt1(i), arrpt2(i))
inter1 = Rhino.LinePlaneIntersection(line, strplane1)
inter2 = Rhino.LinePlaneIntersection(line, strplane2)
If i = 0 Then
ox1 = inter1(0)
oy1 = inter1(1)
ox2 = inter2(0)
oy2 = inter2(1)
End If
rhino.addline inter1, inter2
f.write(chr(13) & chr(10) & "G01" & " X" & round(inter1(0) - ox1, 3) & " Y" & round(inter1(1) - oy1, 3) & " Z" & round(inter2(0) - ox2, 3) & " A" & round(inter2(1) - oy2, 3))
Next
Dim note,entreplan,epbloc
entreplan = abs(box2(0)(2) - box1(0)(2))
epbloc = abs(arrpt2(0)(2) - arrpt1(0)(2))
note = nomfichier & chr(13) & chr(10) & "longueur fil=" & entreplan & chr(13) & chr(10) & "épaisseur bloc=" & epbloc
rhino.AddText note, array(arrpt1(0)(0) + 500, arrpt1(0)(1) - 500, 0), 50
'rhino.print nomfichier
End Sub
for runing you have to save it in a folder named “ETUDE”
and use a file like this onetest.3dm (61.0 KB)
you have to:
choose name,
select one plane
select the second plane
select one curve
and the other,
normaly the script generate folder “USINAGE” near the Folder “ETUDE” with a gcode… with all point of curve.
Thanks @onlyforpeace, I’ve logged the bug.
https://mcneel.myjetbrains.com/youtrack/issue/RH-50611
– Dale
