Hello, everyone!
I would like to ask you a question concerned with Wallacei X, Grasshopper. I joined the length and width of rectangle to the input parameter(genes) of Wallacei X. I joined the area value from length and width to Objectives to be minimized.
At the Wallacei viewport, I cannot find any places that can check the detail values of length and width per solution. I can only check the area values per solution. Is there any places of viewport that I could check the length and width values per solution?
Or could I try by checking the input datas. If so, how could I join to be able to get the minimized areas values and to know the detailed values of length and width? If you have any better ideas, could you explain it to me?
Thank for supporting! Have a good day!
