Checkerboard pattern and boolean operation
Hi all,
I would like to cover an area (circled in yellow) that is made of intersecting lines with a checkerboard pattern. My problem is twofold:
  • I have difficulties making the checkerboard pattern. The way I am tackling this seems way too convoluted (intersections + expression + dispatch + multiple cull patterns + 4points surface)
  • I am unable to constrain the pattern to the selected area. When making a closed curve from the yellow lines and applying a “difference” operation with the (failed) checkerboard pattern, the bordering quad faces (surfaces) are not getting cut properly and overlap the sides.
Checkerboard from intersections.gh (15.0 KB)
Would you mind give me a hand ?
have a look !!
Checkerboard from intersections_1.gh (17.5 KB)
Thank you for your help !
The checkerboard pattern looks good but I still can’t manage to constrain it to a specific area. With a “difference” boolean operation the bordering quad faces are still overlapping the sides:
Any idea how to remove/cut the overlapping bits ?
Checkerboard from intersections_2.gh (14.6 KB)
have a look !!
Checkerboard from intersections_3.gh (18.3 KB)
Thank you so much for your time and the kind help. It is exactly what I was looking for.
Alternatively I have come up with a different approach, splitting the checkerboard with the “Split Brep” component and filtering the resulting fragments based on the location of their cendroids (inside/outside the cutting curve)
good one ! have u checked some place some corners are not splitting
check for details
later i found some flaws !
good solution !!
