Changing viewport display mode - do not repeat?
Open a new file. Make a few rectangular planar surfaces in top view. From the viewport dropdown, change the current display mode to somethnig else. Hit right mouse button to repeat the last command (presumably Rectangle). However, nothing happens because the last command was _-SetDisplayMode, and that is what “repeats”.
Dunno, just seems odd to me that display mode changes from the viewport menu are considered commands that can be repeated with a right mouse click or Enter, especially if the active viewport hasn’t changed. Shouldn’t _-SetDisplayMode be added by default to the “Do not repeat” command list?
Hi Mitch - I don’t think so - I , at least, repeat that one quite often. It’s usually easier and no more clicky than digging through the toolbars to find rhe AllViewports version. (Set display mode from the menu, right click in each of the other vps)
Yeah, I guessed that might be the case.
I have a toolbar for that.
(the Set Objs … are also all viewports - scripts)
