Hi all,
What is the fastest way to change the order of points on GH? I can only think of listing items and changing the order, is there another simpler way? I would like to renumber them so that I start at zero and end with forty-seven.
Thank you in advance!
Thanks for the quick response!
I am actually trying to create a curve through these points. At the moment, I drew the curve in Rhino just to make sense of these points. Sorry for the confusion.
You could sort them radially. Here’s one approach:
In case the points are on an axis, you could also sort according to their X or Y value
Thank you so much, this works beautifully!
