Hi!
A and B are similar surfaces.
How can I make the numbers of the opposite points of A and B the same?
Flip direction of the second curve. Move Seam point.
// Rolf
Thank you so much Adam!
Can I have GH file? Couse of I am new on GH.
Hi Adam. I was curious, when you’re sorting with edges as the key, what exactly is being sorted?
When you input curves, it seems to use the length.
Just as a check to make sure it isn’t working based on the curve parameter:
That would make sense. I asked because when you scroll over the input to Sort
in the OP example, it doesn’t seem to correspond to anything meaningful. Interesting.
Thank you so muck !
Usually I would input the value I was looking to sort, but I noticed with curves it tends to use the length, so I got lazy and typically drop the Length component.
