I have a surface like that one above. I want to change the flow of control points to have something like that below:
I need this to sculpt that surface, but I also would like to maintainthe past shape as much as possible.
This one above I created with the loft command, which I used over lines/curves pulled to the surface.
Rebuild it in a way which not follow a long surface shape.
Do you know any magic tricks for that?
Thanks. I hope that in future there will be a tool to maintain shape and change control points in banana sheets like mine, maybe using AI or in a way similar to Elmo.
Is there an way to pull surface to surface because loft method creates similar but not same shape.
