The normal configuration is Top, Front, RH Side and Perspective. How can I select a replacement for the Perspective? Often I may want the Left Side or Back views.
Change the viewport: (example) View > Set View > Left, then use “Current view” in the Make2D dialog window.
Thank you. That works great.
