How would one change the annotation style for all the selected text blocks in a file?
Have found an example of how to do it with dimensions but it does not work with text blocks.
Hi Miano,
I did this in a C# comp, but you can easily turn it in to a RhinoCommand. The provided method is a skin and bones and you can easily extend it and add more functionality. Since you didint specify the language, I wrote it in my all time favorite C#
/// <summary>
/// Changes the annotation style of all texts in the current Rhino Doc
/// This method can be easily modified to change evry text object with a a specifc style
///given a List of properties as arguments to the method
/// </summary>
/// <param name="doc"></param>
/// <param name="fontName"></param>
/// <param name="fontWeight"></param>
/// <param name="fontStyle"></param>
/// <param name="textHeight"></param>
/// <returns></returns>
public void ChangeAnnotationStyle(string fontName, int fontWeight, int fontStyle, double textHeight)
Rhino.DocObjects.Font.FontWeight _fontWeight = Rhino.DocObjects.Font.FontWeight.Unset;
Rhino.DocObjects.Font.FontStyle _fontStyle = Rhino.DocObjects.Font.FontStyle.Unset;
switch (fontWeight)
case 0: _fontWeight = Rhino.DocObjects.Font.FontWeight.Unset; break;
case 1: _fontWeight = Rhino.DocObjects.Font.FontWeight.Thin; break;
case 2: _fontWeight = Rhino.DocObjects.Font.FontWeight.Ultralight; break;
case 3: _fontWeight = Rhino.DocObjects.Font.FontWeight.Light; break;
case 4: _fontWeight = Rhino.DocObjects.Font.FontWeight.Normal; break;
case 5: _fontWeight = Rhino.DocObjects.Font.FontWeight.Medium; break;
case 6: _fontWeight = Rhino.DocObjects.Font.FontWeight.Semibold; break;
case 7: _fontWeight = Rhino.DocObjects.Font.FontWeight.Bold; break;
switch (fontStyle)
case 0: _fontStyle = Rhino.DocObjects.Font.FontStyle.Unset; break;
case 1: _fontStyle = Rhino.DocObjects.Font.FontStyle.Upright; break;
case 2: _fontStyle = Rhino.DocObjects.Font.FontStyle.Italic; break;
case 3: _fontStyle = Rhino.DocObjects.Font.FontStyle.Oblique; break;
foreach (var rhinoObject in doc.Objects.GetObjectList(Rhino.DocObjects.ObjectType.Annotation))
Rhino.DocObjects.AnnotationObjectBase annotationObject = rhinoObject as Rhino.DocObjects.AnnotationObjectBase;
if (annotationObject == null) continue;
Rhino.Geometry.AnnotationBase annotation = annotationObject.Geometry as Rhino.Geometry.AnnotationBase;
if (annotation == null) continue;
annotation.Font = new Rhino.DocObjects.Font(fontName, _fontWeight,
_fontStyle, false, false);
annotation.TextHeight = textHeight;
annotationObject.CommitChanges();
Thanks, I am doing Python on a mac but can convert.
