When I right click a stack of points, each object reads ‘Point’. I can add a name (such as NewName) by modifying the user attributes which would result in me seeing “Point - NewName”. However I’d like to change the Point text. I assumed I could do this by changing the RhinoObject.Name property but this is the same as modifying the attributes. Is what I’d like to do even possible?
I’ve put some example code here;
Guid id = doc.Objects.Add(point);
RhinoObject obj = doc.Objects.FindId(id);
obj.Attributes.Name = "NewName";
obj.CommitChanges();
Results in “Point - NewName”
obj.Name = "NewName";
