I’ve run into a strange glitch where Rhino’s extrusion method is no longer NURBS. Instead, all curve extrusions are generating Meshes. Where can I reset this so Rhino creates NURBS as it should be doing by default? Thanks.
Hello - Rhino never makes meshes from the ExtrudeCrv command - by default is makes extrusion objects
You can turn this off and get only surfaces/polysurfaces by using the UseExtrusions
command.
