Chamfer type in Tekla
Hello
Is it possible to check how many contour points the sheet metal has and what type of chamfers have been used? I saw one option in “Expand object” component but I can`t find contour component.
You can keep applying the Expand Object component to the outputs to further extract properties.
If we do that, in this case I noticed we’re not actually getting the chamfer properties because the contour points get converted to Tekla control points automatically. I’ve made a change to how that works in this update:
[EDIT: Latest installers on Tekla Warehouse ]
With that update, you’ll be able to do this:
Note that using a GH curve param at the Contour output like in the pic would not have any chamfers applied, it’s just the polyline.
Cheers,
-b
Thank You Sebastian
