In the attached I have two edges that I would like to Chamfer. One is marked with a rad line. The other is outside the picture but is roughly the same.
I need to chamber the edge at 45 degrees so that the surfaces on the left of the edge slope into the ones at the right. Because the surface I want to replace varies in height, need the chamfer should disappear when the height reaches zero.
Is there any way to chamber the edge by angle (rather than length)?
Problem Chamfer 2.3dm (3.2 MB)
