Seems chamfer surface causes a crash. I tested this with turning off the trim and same crash. That was a simple extruded box I started with.
I see that and will get right on it. Thanks.
Fixed for the next build.
Thanks chuck!
Speaking of chamfers, I posted earlier about this but what about the possibility of stating angle and distance for perimeters of a chamfer ? I’d prefer this option for chamfer edge but having it for chamfer surface would be nice too.
This has been requested before and is on the list. I don’t know when we’ll get to it. If I have a chance I’ll try to put together a test command for ChamferSrf. No promises about when, though.
Do you think it will make it’s way into V6 ?
No, it will not be a regular feature in V6. If I can come up with a reasonably useful test command in time, there may be access to that in V6 or in whatever our WIP process is once V6 is out.
Okay. Thanks for the hasty response Chuck.
