Hi, I hope to get an answer to my problem!
I created a Box 150x100x6mm, now I like to create a chamfer 0.5 by 0.5mm on all sides, what can I do?
run chamfer command?..
or actually the ChamferEdge
command.
Select the NextChamferDistance=
option in the command line, type 0.5, and drag a window around the entire box to select all edges.
I hope this is the same on Mac…
Thanks wim I can tell you “I’t works”
