Capture Named View without activate?
Recently I modify a bit of my previous script (capture using rect) to capture views with ViewNearCorners.
However it was set up by using Active Viewports, meaning I have manually turn on Named Views one by one in order to capture those.
I wonder if there’s a way to do the capture without activating them?
import Rhino
import System.Drawing
import Rhino.Geometry as rg
import scriptcontext as sc
import Rhino.Display as rd
import System
for i in view:
    RhinoDocument = Rhino.RhinoDoc.ActiveDoc
    selectview = RhinoDocument.Views.Find(i, False)
    viewcorner = rs.ViewNearCorners(i)
    clientarea = selectview.ClientRectangle
pt0 = viewcorner[0]
pt1 = viewcorner[1]
pt2 = viewcorner[2]
pt3 = viewcorner[3]
width = clientarea.Width
height = clientarea.Height
fector = float(fector or '1')
size = 'w=' + str(int(width*fector)) + ', ' + 'h=' + str(int(height*fector))
def Capture():
    size = System.Drawing.Size(int(width*fector), int(height*fector))
    settings = rd.ViewCaptureSettings(selectview, size, 300) #view, size, dpi
    settings.SetWindowRect(pt0, pt2)
    settings.RasterMode = True
    settings.DrawGrid = False
    settings.DrawAxis = False
    settings.DrawWallpaper = False
    bitmap = rd.ViewCapture.CaptureToBitmap(settings)
    bitmap.Save(path+str(filename)+".png")
if save:
    for i in view:
        rs.ViewDisplayMode(i, mode)
        rd.RhinoView.Redraw(selectview)
        Capture()
        print(path+str(filename)+".png")
Any thoughts here?
